1 - 6 of 6 Posts
Almost 4.000 Km on counter and love the bike more and more. Sound level seems to improve.
Did some DIY improvements on my bike
- Got rid of the license plate lighting in order to mount it higher. License plate in Belgium is narrower then the blinkers.
- Other mod I reported earlier is something MY2010 owners should try, if they are riding on open roads as I do. Swap the clipons from side, the angle becomes less downwards and you can turn them more towards the tank. This improves the seating position a lot, you loose a little bit of control though and it takes some time to adapt. I did a few 600km trips without any problem. And putting them back to standard position takes only 15 minutes.
Also installed (insane expensive MV original but perfect quality) carbon front- and back fender. It really improves the looks of the bike a lot.
I DIDN'T GET IT?????????????
He said to swap the left and ride clipons (handle bars) it will change the angle so you are sitting more upwards.
Didn't take you long to rack up 4000k's
Nice work!!!
a ha i c
thanks Joe
1 - 6 of 6 Posts
