1 - 9 of 9 Posts
· Registered
There is no simple "decat" system available; most companies offer a slip-on muffler including decat and removing the exhaust valve. Once that is done, you will need to reflash the ECU (check www.Rexxer.com) to richen the mixture or buy a Power Commander or the factory race ECU. The Rexxer guy claims they've done dyno runs and the stock muffler is pretty restrictive.
· Registered
I rode an F3 675 (black) [so that we can distinguish between the two mentioned later] that had been decatted and hollowed out. It sounded amazing from 6000 upwards with this massive growl, but I was very disappointed as it lost all the bottom end power and even some of the power at higher rpm's. I don't know if it needed to be chipped/mapped to resolve the issue. However I am used to my F3 800 but the other standard F3 675 (red) I rode was perfect all the way to 15000. Unless there was something wrong with this particular bike, I definitely would not do it. I felt that even on pull off it was noticeable and if you where at 6000rpm and above and opened the throttle suddenly, nothing happened but noise. I mean literally nothing happened. I think the bike needs backpressure and this might just get rid of that. Loved the sound and considered it in the beginning but the more I rode it the more disappointed I felt. It might be different on the 800 but I doubt it. Just my opinion though.
· Registered
ECU Reflash
Confirms my suspicion as it was posted just as I was typing....
· Registered
So far the systems that seem to make sense for the F3s include the Zero, with its OEM-look, 3-pipe outlets, and the HP Corse Evolution, with its hydroformed 3-into-1 muffler. Both systems stop the outlets short of the rear wheel to keep it in full view, unlike the Akra and Termi versions.
· Registered
The lenght of the pipes plays a role on the gaz trap . The stock triple short is very good looking and noisy but you gain torque at all curve with longer single pipe(used in racing ), and with a db killer you may ride on limited noise track days. There is no need to remap too, it's a slip-on with the original valve and cat .
1 - 9 of 9 Posts
