I removed ugly decal fromt the top of my gas tank (2012 Brutale) only to find it let an outline of the decal which was covered by a clear coat. What is the best source for decals? I need one larger of maybe an Italian flag or a big MV decal
You sure it is not just glue residue?
Try using something like WD40 (I use SAS) spray on a soft cloth and gently wipe over the outline. It is as stubborn as anything that glue, so wet the area and leave it to soak and keep wiping over the area. Polish etc will have far less effect, but can be used when all the glue has been lifted by the WD40.
If it doesn't shift then yes sounds like they clear coated over the decal, but that would surprise me.
Dave
thanks all. Yes it had a coating on it and there is a nice outline of the decal. I filled it in with some clear adhesive and will put a new decal over it.
