My PULSE battery went dead last nigth, and I need to remove to be charged, there is no outlet to plug in the PULSE charger where my bike is located; is there any sequence or way to disconnect the cables, in my other bikes there is no problem, but I never did this on an MV Agusta, please help this NewB; I did search this thread for any info, none was found, much appreciated.
I do have the correct charger for the Pulse; so the battery can be taken out of the bike, and put back with no other gimmicks.
There is a Standard Electrical Practice!!!
There is a sequence for the battery cables!!!!!!
Always remove the ground cable first. On the MV that is the NEGATIVE(-) cable.
This prevents any possiblitiy of establishing a circuit off the POSITIVE (+) cable to any grounded piece...i.e. the frame.
Install in the reverse: POSITIVE first, NEGATIVE second.
This is true for all vehicle electrical systems.
As, Donsy said: DON NOT REVERSE THE POLARITY OF YOUR BATTERY.
Pay attention to how it is installed before disassembly....note where the terminals are.
