1 - 3 of 3 Posts
So... I noticed that the dash cover was sitting low. Low :) and behold the little plastic mount was broken. So I have used some epoxy resin (two tube mix stuff) to fix, but after a couple of days that broke again. Have now used some PVC cement... And have left that to set, but after about 20 hours or so, the weld still seems soft. Give it some more time?
Ps any other ideas?
Try JB Weld if what you have done doesn't work.
+10
I've never had a JB Weld failure......
It seems to survive everything...... I recommend it for plugging the fuel pump plate
fittings when modifying the tank lines
I TIG them because it's faster LOLOL
:drummer:
1 - 3 of 3 Posts
