1 - 20 of 22 Posts
Gave the chain a clean and lube last night after a quick spin and noticed a good amount of play in the sprocket carrier.
And so I need some cush rubbers again! Can anyone recommend me a place to in the UK that will deliver quickly?
Bennetts?
Or replace with the old style, 50 to 80 quid off ebay. Means no more rubber replacements.
I'll pm you later today, just seen msg
Cheers Arron
Do yourself a favor, buy a "Quick Change" 1st Gen cush drive.......
Problem solved...... I'm at 38,600mi/62,100km and there's no wiggle at all:grin2:
Yes, I checked
And they fit
OK, so a 1st gen cush drive it is then.
To make sure I buy the right part, would somebody mind pointing me to a specific advert or ebay link?
Or a pic of what I need to buy.
Thanks Noel - you are a gent.
Does that mean gen1 cush drive is better than gen2 ones?
Reactions: falcn
Yes. When MV went away from the round cush drive rubbers, the system degraded quicker.
Good to know as I just mounted one. But I check my stuff regulary so should always be okay.
Yes, Erik, there are people getting 3,000mi to a set of 2nd Gen cush drive rubbers
On my 1st Gen I'm coming up on 39,000mi with NO WEAR!:grin2:
Here are the things I see.......look at the last picture carefully......the 10mm hex is GONE!!!!
You think maybe a little too tight>:)
Check the reverse taper on the head......they stretched it lolol
Ok stupid question, does a gen 1 fit a 2015 Turismo? And what bikes do they come from any model or all models?
The stuff you come across... incredible...
That must have been a very special mechanic.
Erik, why do you think I don't trust others to even sharpen a pencil?
Noel's "Hall Of Shame" exhibits !!!! Not for the faint of heart.
Yup, UK seems to be the best source at present to purchase replacement cush-rubber blocks.
Growing number of Gen-2 owners thinking and converting to the Gen-1B sprocket carrier (or after-market cush combination).
e.g. (just an example)
https://sprocketcenter.com/superlite-superflex-polyurethane-cush-drives-for-mv-agusta-750-5-piece-set.html
I'm one of those Gen-2 guys that went to a Gen 1 aftermarket from BDS.
https://www.mvagusta.net/forum/21-customising-performance-section/241957-bds-chain-wheel-adapter-kit-any-feedback-2.html
1 - 20 of 22 Posts
