So I knew they were failing, pretty obvious to see. So I got a new set and was kinda holding on to them until I was going to get tires mounted and have it all done at once. So I could see the rubber tearing away from the nut, but thought if I took it easy I could get a few more miles. So rode to a GP viewing party today and just in case, brought the parts and tools with me in a backpack. When I arrived, the bolt part of all 5 inserts was completely against the metal side to drive it forward. I could see light through the huge gap in all of them. So time to switch out. Pretty straight forward swap. Back in business.
So my question is, why am I doing this at 12,500 miles and when have other owners seen failures of this part?
I'll post pics of the damage here shortly.
Like so many things Jason, I think it's a question of which production batch you had on your bike, who made them for MV at that stage.
Maybe also a question of how you ride your bike? I've replaced one set on my bike over the years, but have replaced sets on customers and friends bikes, one on a high mileage 750 and the other set on a low mileage 312R.
Almost like the later versions where not as good quality as the older models, maybe due to MV switching suppliers?
Anyway, the one's I got from Al as well as the Ducati one's I got from eBay seem to be okay.
It would be good to hear what others with the same system have experienced, I know there's been some very low mileage failures of the y10 F4 and B4's but they use a completely different system.
Could just come down to how hard you ride, and the power/torque output from the perspective motor. My friend has a 1999 Ducati 996 with 57000 miles with 1 replacement, but he doesn't ride very hard and rarely in the upper rev range...I'd say pampered miles. What is the normal lifespan for cush drives anyway?
This new set came from Design Corse. They look better than the stock ones. I had to use a bench vise on the old ones to get the nut off because there was no way to hold it otherwise. The new ones are slotted in the back for a large allen wrench which also made tightening them on install much easier.
92 lbs of torque, last Dyno. I kinda ride the hell out of it.
I replaced cush drives on my Brutale 750 at about 38.000 km.
