1 - 3 of 3 Posts
Just had my 1090 serviced and they noticed my cush drive had excessive play in it. Bikes only done 6000 miles. Its being replaced under warranty.
All you 1090 owners, check to see how much movement you have on your rear sprocket (forward and back) if theres play in it, get in touch with your dealer and they should replace the rubbers under warranty.
Thanks for the info - my 1090 has 730 miles on it and the rear sprocket has loads of play both side to side and in the direction of rotation - my local dealer said it was normal - I'll get onto them and insist the cush drive rubbers are changed
1 - 3 of 3 Posts
