1 - 19 of 19 Posts
The set up:
2004 Brutale 750, stock Marzocchi forks, Moto Corse radial caliper mounts, 108mm bolt spacing.
The problem: I don't have the calipers anymore that fit those caliper mounts and I don't have the fancy rotors:
The fix: I have 320mm rotors and calipers, but I don't have radial caliper mounts to fit the stock radial calipers. I have stock marzocchi forks, but no stock calipers or rotors.
As a purveyor of parts generally known for having quite a few in stock, this is an embarrassing situation.
So who has some ideas about what to do? Any body want to trade anything?
I've already rejected the suggestion "just forget about the whole thing and give the bike to me" idea.
Just forget about the whole thing and give the forks to me. That works? Notice, I wrote forks, not bike, so, maybe, somehow, somewhere...
''The fix: I have 320mm rotors and calipers, but I don't have radial caliper mounts to fit the stock radial calipers. I have stock marzocchi forks, but no stock calipers or rotors.''
On a second note, can you explain this? Aren't the 320mm rotors and calipers stock radial setup?
And which stock marzocchi forks? The regular ones from Brutale with axial caliper mountings?
I thin there is no easy fix, since you can't make custom brackets to fit any other calipers on 108mm mounts.
Sure. The caliper mounts on the forks now, stock Marzocchis, are for 108mm bolt spacing. The stock radial calipers are 100mm bolt spacing. So, although I have radial calipers, and the correct 320mm rotors, they won't mount on the forks I have now.
I also have a set of forks from a stock 750, but I don't have 310mm rotors or stock axial calipers.
The set up:
Wel Carl, I'm glad to help you with a quote here, from the late (and great) Dennis Hopper.
I saw him opening the Rotterdam Film Festival almost 20 years ago, I brushed elbows with him later, but in his speech he recounted the following telephone conversation with his ex-wife Michele Phillips (she was in Mexico, he was in Taos):
She: "I'm leaving you!"
He: "What am I gonna do, what am I gonna do?"
She: "Have you thought about killing yourself?"
So I'm offering you this quote (noting that Dennis didn't actually follow up on this well meant piece of advice), and now expect something in return.... :)
That clears things up.
With the statement that you cannot make custom brackets I meant that there is no physical room to do it (and not you being incapable of doing that), since 108mm and 100mm is so little difference. You could if the mountings would be let's say 150, than you would have enough room to make new bracket and bolt on the 100mm calipers.
When I was still riding mountain bikes few years ago, I went from 160 to 205 mm rotor on the front wheel. I simply made a new bracket from stainless steel and off we went. But then again, the caliper was axial mount. Oh, and the forks leaked oil twice on the sealing, since they were bending so much under hard braking.
Looks like you need a new set of calipers or mounts. Or both.
The cheapest route would be to buy some 1000rr or 600rr calipers. (just about any modern jap. sportbike caliper will do....not withstanding the modern R1) Or you could buy some Brembo GP4-RX calipers i have.
On the other hand if the 100mm brembo calipers you have are the squared off gold kind, then i have a nice practically new set of 1000rr calipers i'd trade.
310/320 wtf?
Carl;
i have;
an extra set of MotoWheels radial bottoms, 100mm spacing for 310 discs currently on the F4 (Josh sold me his German ones)
a extra set of BrakeTech iron discs, 310mm they are the early un drilled ones
if these will help, we'll talk
:f4::brutale:
Assuming the C/L of the rotor opening of the 108 vs 100 calipers are the same when mounted (ie; no big time shiming required to center the cals on the rotors) you're off by roughly .320". The only solution I see, at the moment, would be to TIG some aluminum (not mag I hope) on the caliper mount ears and holes and drill and retap the holes at the proper spacing. Lota' work and half assed but it's an option I'd consider were I on a desert iland wi' no other choice. Desperate move though.
you could just buy a pair of R6/R1 108mm calipers for cheap. They are a totally decent monoblock calipers and pretty cheap. A lot of track guys have "upgraded" to them on suzukis
I am offering nothing....you're screwed.
Well Cag,
As a colleague, I could cut you a good deal on a set of original axial calipers that I have in stock, new.
I guess I should clarify.......I don't have any solutions I can offer....sorry Carl.....I guess you are screwed. :eek:
We are ALL doomed :lightning
Discussion Starter #18
Solution found. I will be using the stock forks, stock axial calipers, and brake tech rotors. This was the least expensive option since I found all the parts.
I need a better system for my inventory.
Been There. Seen the pile after pile of "inventory". Good luck.
1 - 19 of 19 Posts
