1 - 12 of 12 Posts
I have been looking for good quality frame/body sliders and it seems that to install any descent protection I would have to drill the side panel. I don't want to do that because the hole will interfere with the side panel RR graphics. Can you guys advise what's out there? Basically I am looking for a set of slides which will protect all the painted plastic panels on the bike if it drops.
I am looking at this one right now but it seems that the bracket would bend because the actual slider protrudes from the mounting point on the bike:
http://www.ebay.com/itm/Frame-Slider-Premium-MV-Agusta-F4-Brutale-1090-Matte-black-/281643034423?fits=Make:MV+Agusta|Model:F4&hash=item41933ba737&vxp=mtr
Your help would be greatly appreciated.
Those are in the mail on the way to my house already; although, they look like they are absolutely the worst possible engineering solution for protecting the bike. The mounting point is away from the impact point. It is fine if the bike falls when stationary but if the fall occurs at any speed, the slider would rotate and rip into the panels. The back side of the impact puck may hit the frame if the bracket bends during the fall. Once it is here, i will see how i can improve on the design. It is stupid that this is the only non invasive solution out there for the current gen F4.
Banned
Retrodrive, sounds like you have a pretty good handle on the solution. :)
Frame sliders are crash protection, designed to allow the bike to try to save the frame, not the bodywork. A bike that slides on it's side tends to get damaged a lot less than one that cart-wheels.
And "sliders" that mount on offset brackets, are not frame sliders, nor are they crash protection, in fact they tend to make crashes worse, by bending frames. And keep in mind that any frame damage on a motorcycle is going to render the motorcycle a total loss.
There's not really such a thing as "tip-over protection", but proper crash protection will often minimize tip-over damage. Frame sliders (proper frame sliders) are obviously going to help. Rearsets with non-folding pegs can help. Bar end sliders are going to help with both crash protection and can also reduce tip-over damage. And removing the rear view mirrors will help to reduce damage to the upper fairing and minimize chances of bending or breaking the "ears" of the fairing stay. Some bikes, with the above prep work, can actually lay on their side without any paint touching the pavement.
For bikes that get used at the track, proper crash protection is important. But for bikes that are only used on public roads, I don't think it really matters- I mean, we all have full-coverage insurance, so whatever gets damaged, is going to get replaced.
Well, I have already installed them on the bike. Everything is exactly as I was thinking in my previous post. Now they will work very well if the bike just tips over, as no paint would be damaged anywhere. In case of a fall at any speed, they will cause more damage. I want to come up with some sort of bracing for them to fix the sliders in place and stop them from rotating in the event of a fall.
So R&G are finally out with their sliders. Not pretty, as always, but I am wondering whether they will get the job done. Normally, R&G produces quality products. On the web site they are not showing how the slider mounts to the frame, which is the most important part. If it mounts to a single bolt and would rotate around it in the case of a crash, it seems as useless as the previous slider I ran...or a blatant copy. Anybody has this on their bike? Can you post a picture of how the new R&G slider mounts to the bike?
http://www.rg-racing.com/browsetype/Crash_Protectors/MV_Agusta/F4/CP0397/#
I will inquire with R&G directly also.
Hi
Its worth considering protecting the crankcases and forks/rear axle as well.
I fitted GB Racing case protectors recently, a 15 minute job to fit and they look better than I though they would.
I also use R&G axle sliders, the front is not particularly attractive but there is a new version that looks better, the rear looks okay.
My old 1000S has plastic mushroom shaped bungs fitted to the frame/cylinder head engine mounts which would give the frame the protection of about 5mm of plastic before it touched the ground. I think Xbikes does them for the later bikes.
Yeah, the GB pieces were the first mod on my bike :) I am waiting for RG to respond but if they do, its going to be after the weekend. Meanwhile I thought somebody may know something.
My concern with the slider being offset from the mounting point is that it would rotate during the slide and damage the frame and the panels even more. You need at last 2 anchor points to keep it from moving.
1 - 12 of 12 Posts
