1 - 3 of 3 Posts
Probably no need if you don't remove the catalytic converter. If you do the de-cat and the mufflers you will need the ECU.
Will run very lean without. No so much so with Cat still in place. Shouldn't damage anything, but may get a bit more after fire on decel, the 02 sensor will prevent too lean a mixture at low speed and idle.
Do it (the entire system with ECU)...It really transforms the bike all the way around.
Thanks for the reply, was thinking of this as a half way setup while I save up for the full system.
1 - 3 of 3 Posts
