Brutale dragster 800 rr my15
Filled reservoir and I think it need to drop down through the system but it’s not...
Any ideas on how to ?
Or do I just have to do a flush and refill?
The reservoir only lets fluid into the system when it is cooling down. To fill the system you need to access the radiator cap itself.
Going to do a flush on it then.
So a couple of q’s.
Do i really need to lift the tank to get to the expansion tank? Won’t filling the reservoir quick heat and cool cycle fill the expansion tank? Can’t I just access the radiator cap and fill from there ?
Also, what sort of quantity of liquid do i need to buy to fill the system?
Cheers in advance!
You need a couple of liters of coolant. Just go to the auto supply and buy a gallon of quality "long life" coolant. It's the same thing as sold in motorcycle dealerships with fancy labels and brand names....but with a much lower price.
You need to fill the expansion tank because you never quite get all the air out of the radiator and hoses/passages, and the tank provides a small supply to fill the voids....also, you can't overfill the radiator so there is any extra to fill the expansion tank to its minimum level.
Reactions: Digital
