Hi all!
This is my first post. I took delivery of my 910 this week and apart from having to sort out the peg position I'm in total love with it.
I've read a couple of posts on fluid leaks on new bikes but I was wondering if any of you guys could tell me if you had experienced loss while riding and if it's sprayed around the left side of the engine/frame? I'm kinda worried that I've got a worse problem than the bike just finding its fluid level.
I've noticed coolant under the bike a few times recently. Was thinking it was due to the warmer weather...but I'm going to investigate further
It's a bit of a worry. My brothers MK1 Senna had a water pump issue.
The engine has been running anywhere between 84c and 103c.
And has your R had coolant up the frame/ engine?
So do I...my mechanic says that there is always been some trouble with the water pumps on this bikes. Mine is still under warantee so he's ordered a new one to MV Italy.
had the same thing with my coolerwather
needed new fitting and problem was solved
(you should tell your dealer about this prob)
