1 - 20 of 20 Posts
Hi lads im looking for advice,ive just noticed when i start my bike up there is coolant dripping from the housing where the hose is attached (excuse my ignorant names on these parts).I presume there is a seal gone would i be correct,is it difficult to fix and where is the quickest place for a replacement one.Cheers,Philip.
It sounds like you need to replace the quick release hose clamp with the normal adjustable hose clamp.
See if the coolant is coming from the relief hole under the water pump.
If it is a new water pump seal is required.
Thanks Mitcy i will have a look,if this is the case where is the quickest place to get one
Are there any issues with Star Twin as i get a warning on my computer about an unsecure website when im tring to purchase the parts i need.
@phillo45: It could just be the picture, but why does that "drip" look to be yellow to me?
I would expect green or blue were it coolant...maybe even red, but not golden...:nerd2:
I'd say Prestone is more yellow than green
:grin2:
:crazyeyes:flash::crazyeyes
Another picture
Very likely the seal has worn..However, being the eternal optimist, I couldn't help but notice an overflow pipe resting on the water pump housing. Are you certain it's not trickling down the coolant overflow tube from the expansion tank ?
Dry it all off and have a look see...:nerd2:
Good luck !
Joe
@gototjoe: On that side, the hose is from the fuel tank overflow/drain.
coolant leak 989r
Phillip, even though you sold your bike, you seem to have had the same leak as i had , but it wasn't the pump failing or the oring on the front of the pump
It was the hose hanging down in the photo which is the radiator spill hose . it was tucked down the left and on a hot day a few
drips made there way onto the cover . so i just moved the pipe so you can see it in future. it can really send a false symptom to you.
1 - 20 of 20 Posts
