2014 Brutale 675
My coolant is constantly leaking from the overflow tube. I thought it might be from idling around in traffic too long but it keeps leaking after I refill the tank. No signs of leaks anywhere else.
Has anybody experienced this issue? Is it something to do with the thermostat?
Hahaha, 4 cylinder 675, must be new model. Have a look in the next section down buddy. Lots of discussions on this very topic.
Most probably simply emptying out excess fluid since you should be running the level on low, but it could be a faulty cap or air in the system too.
As Donsy says, could be an airlock or faulty cap, but the triples do run on minimal coolant, so if you're topping up all the time it may just be emptying out what you put in.
2014 Brutale 675
this is what I do to all the bike I owned, take off the coolant cap start your bike let run to temp 150 degree turn off your bike, then lean your bike to the left shake it couple times and lean your bike to the right shake it couple times then turn your bike on again let it run to temp 160 degree do the same as first step then refill to your coolant to Minimum requirement level recap it ready to go
