1 - 14 of 14 Posts
Will forks from a 2007 model F4 fit on an older model F4. Is it a simple matter of just swapping them? I know the brake disc are different sizes and calipers need to be changed.
yes, they will fit. You'll also need the radial fork axle and spacers (depending on your wheels), and new brake lines.
number2;
you will need the spacers (all MVs use the same wheel bearings <'10, '10+ ???)
and brake lines
that said there are radial bottoms available for the early style big axle and 310mm and 320mm discs you use different spacers
they are going on my '05.....it already has radials but I don't like the bottoms
King of Bling
Noel
The brake lines for the Radial set up on MV's has a different brake caliper union angle and brake hose length to the early Showa none radial set up..
Depending on what calipers you're using, the F4 1000R or F4 312 factory front brake line will do the job..
John;
go back and look at post #4
I know they need brake lines...
my '05 has radials, big axle, 310mm discs, PVM hydraulics and Cycle Cat riser bars
next new bottoms for 310 or 320 discs
got them, just haven't put them on
:drummer:
John;
:drummer:
With radial forks on the bike wouldn't one be able to switch between the different size rotors by adding/subtracting a 5mm spacer set between the caliper/fork?
Not exactly.
E.g.: The radial bottoms from Brutale 910R forks are made to fit the 320mm rotors and you cannot subtract anything to fit the 310mm ones, but on the Brutale 989R, the radial fork bottoms, that are made to accept the 310mm rotors, you can add 5mm spacers to fit the 320mm ones.:nerd:
Cheers,
Laur.
King of Bling
Laur is correct... I noticed this issue when the later radial fork Brutales were launched.
However, this isn't the case with the post 2010 F4's, and you can swap between disc options by interchanging the space between the caliper and fork mounting... Ducati do a nice OEM CNC machined spacer for their 1098 which does the job..
Not exactly.
Cheers,
Laur.
Ah, now i see says the blind man. And i suppose suggesting 'trimming down' something on the Agusta for more options is sacrosanct round these parts.
Yes,
my aftermarket CNC bottoms came with 2 sets of spacers for 310 & 320 discs
they are NOT FLAT spacers, the bottoms are counterbored to fit them
:naughty:
:drummer:
1 - 14 of 14 Posts
