1 - 6 of 6 Posts
Is it really just 3 bolts to remove the collector box? I want to remove for polishing coz its showing rust on the upper surface . Manual shows three bolts - surely not that simple - its an MV!
Yeah don't see why not, had a nosey at the manual and looks simple enough.
Yupp, just 3 bolts.
1 on left side, 2 on right side, than just slide it backwards off the cat.
Might want to put a little bit of sealant around the join when you put it back on. Mine was blowing at the joint. There's a double flange but no gasket.
Don't put it back on. Looks so much better off!
1 - 6 of 6 Posts
