1 - 6 of 6 Posts
My 1078 brutale seems to be weeping a little fluid from the slave cylinder..
ive looked everywhere for a diagram of the cylinder and or seals/o rings but cant find anything. can anyone help.
the seal is a lip type master cylinder seal, the bore of the slave is 30.2mm
the ID of the seal is 21.0mm tapered and the width is 5.0mm
i never found any....good luck :drummer:
Same here, most guys just buy an aftermarket slave cylinder, I use the Oberon, but there are other options too.
Many thanks guys, i had a quick look at the seal today and it looks like whoever fitted it poked it in with a stick and a depresion can be seen on the top of the seal.
Anyways i will buy an oberon or mv corse replacement in the near future, funny thing is it now seems to have stoped leaking.:)
seal?
the seal is an 1 3/16" master cylinder seal....car stuff
problem is nobody wants to tell you the M/C bore size or sell the seal to you.....you can thank lawyers for that BS (listening Elton)
MVAGOGO;
find out who sells a nominal 30mm slave......ask them the ID of the seal.....job sorted
1 - 6 of 6 Posts
