So Im planning to replace my clutch hub with the updated part (see threads on failing clutch hubs). I purchased the new hub and it has arrived, but the dealer (not MV - MV went bust in South Africa) insists that I replace the clutch rubbers as well as he fears they will be due for replacement (mine is a 2012 with the original rubbers). The dealer poached a lot of the MV mechanics before their demise so I would say they are the best option I have. I cannot replace the rubbers under warranty either.
So on to my problem:
The Startwin tell me the price for a single clutch rubber (8A00B6484) costs 18.92 euro each (I need 6).
This is a very similar rubber to the rear wheel hub rubbers (8000B2151) which cost 1.35 euro each.
Evolutionbike also told me something similar some time back when I ordered the hub from them.
Am I going nuts? Im thinking the price of 18.92 euro must be for a set and not for a single rubber.
Anyone that has replaced theirs that can confirm. Shooting myself is seeming very appealing right now as the cost of the rubbers will be more than the hub itself.
The cost of this preventative exercise (in part due to MVs shit QC on their first generation clutch hubs) is starting to get really expensive.
Pull the original clutch rubbers out first and inspect them before you order new parts. They are not easy to get out as the six fasteners are loctite in place and it takes a bit of heat to loosen them up.
The rubbers get sandwiched in place between the basket and gear plate. I put a bit of self vulcanizing rubber on both sides of the original rubbers and around the outside edges near the basket holes. Let the rubber cure before fitting the basket to the gear. It fits very snug that way.
I’ve been replacing anything with an MV Agusta logo on it and that seems to do the trick. Replaced the entire back end with AEM parts. Those rubbers now cost over 100.00 for an entire set but they last!
https://sprocketcenter.com/superlite-super-flex-polyurethane-cush-drives-for-ducati-5-piece-set.html?gclid=Cj0KCQiA8f_eBRDcARIsAEKwRGd-HLAfl9jv1bt4QFBNFhLeVOFnE_DgEJQRCUtUzqvJ-KIkLFX3YMMaAsKfEALw_wcB
Not saying this is the best option for you but I can guarantee your issues will arise again.
Any reason for the vulcanizing rubber? I had a look at the latest service bulletin regarding the updated basket and rubbers(bulletin 214) and they only mention greasing the rubbers before installing...
My rubbers are arriving tomorrow so will be tackling this in the next few days. Cant say I'm looking forward to it.
