I'm installing bar risers on the F4/750. I need to change out the stock clutch reservoir to a remote unit like on a 1098. Has anyone taken theirs apart? There is a screw inside to remove but then there is a missing dime shaped plug missing that would attach to the fluid hose. I've seen the plug part for a bembo but do not know if it is the same size. Any ideas? For the front brake I replaced the whole master unit but do not want to do that for the clutch. THANKS BobL.
remote reservoir?
Alex at Gutsy Performance has the reservoirs i'm not sure what you need to connect the hose to the M/C
Here you go mate, this is what you need.
http://www.performanceparts.de/MV-AGUSTA/F4-750-1078/CLUTCH-BRAKE/master-cylinder-adapter-set-for-external-reservoir.html
That is what it looks like, not sure if I have seen them for sale by anybody else.
Brembo fits Nisson?
Yes, thanks, that is the part. But at $85USD I can almost replace the complete M/C from ebay parts, and I only need one. I found the same in Brembo but do not know if it will fit the Nisson.BobL.
That's what I thought too, I have no idea if the Brembo parts has the same dia, would be really surprised though.
