1 - 10 of 10 Posts
I was working on my 2007 brutale 910 r and was removing a piece of asphalt that was stuck in the front sprocket cover.* I had to remove the front sprocket cover and was being care not to remove the cylinder rod but as I was holding it in place it slipped from the pliers and slid out with the cover still in place in the slave cylinder.*It seemed to be stuck in the slave cylinder. I placed it back in and put the cover back on.* I started the bike and the clutch worked fine.* It went in into gear no problem and I was able to go back to natural.* I was nervous to take it for a ride.*I am unsure what to do. The piece of asphalt was almost glued to the inside of the sprocket cover.
It's fine, at the very worst you might have damaged the gearbox oil seal, but maybe you where lucky and it's all fine.
On you model there's nothing else that can go wrong.
I will keep a look out for any leaks. It's still to cold around New England for any daily riding. I will try to get it out tomorrow and get it up to temp. Thanks!
Hey Donsy, I may have done this....Which part number is the gear box oil seal?
Hi Glenn.
I'll respond here instead of the PM you sent me - sorry I missed your post before, too much going on for me to handle at the moment.
1st you need to check where the oil is coming from, on the clutch push rod it's very discrete but all over the place, it could look like a leak near the waterpump or look chain lube spilling out from front sprocket. And this is a gearbox removal job as the seal is inside the gearbox.
2nd option, and more common, is that it's the front sprocket seal leaking, more messy and shows the sprocket as oily mess. This is easy to do without gearbox removal.
I'll post pics and part numbers ASAP.
Thanks, for the reply mate, I figured you had not seen it and I appreciate your expertise/knowledge. Keeping it on the forum benefits everyone. Mine looks like it is coming from the water pump initially but then realised it was being pushed around by the air flow.
As I said in the PM, I'm swapping out my swing arm, so figured I would fix this at the same time. I have had a couple of little leaks, but she is 17 this year so hopefully I will have them sorted out soon. This one seems quite small, as I still take it out every few weeks or so.
Thanks heaps for your assistance. I will owe you a beer if you ever get into parliament and have to come to Canberra :)
For what its worth, I was chasing a leak on my 910S a while back and had the sprocket cover off a number of times. On each occasion the clutch push rod refused to stay put so inevitably it came out. I simply slid it back into place and maybe I was just lucky but the gearbox seal is fine.
My problem eventually turned out to be twofold, the countershaft seal was leaking and I sourced a replacement locally from a bearing and seal distributor, I just made sure it was Viton. Having sorted that, the oil leak persisted, albeit greatly reduced. Turns out the sump gasket was also leaking, a very simple repair with a tube of Toyota liquid gasket.
Now she's as dry as a bone and I'm happy not to be wiping the back rim down after every ride.
Push rod seal
Push rod seal is Part #9 - Part number 800091603.
Size is a 16x8x5
Countershaft sprocket seal is #7 - Part number 800089410.:wink2:
Size is 35x47x7
Cheers mate, Thank you very much!
Edit: In case someone else reads this part number 9 pictured above is actually 800064296, RETAINER, AXLE, CLUTCH DRIVER
I think Dons transcribed part number 8 instead of 9 as he meant too :)
1 - 10 of 10 Posts
