1 - 14 of 14 Posts
Hey Guys!
My 2004 F4 has a clutch that drags when I have the clutch lever pulled all the way in and in first gear. If I let the brake lever go, the bike will lurch and keep going if I let it. Here's what I have checked so far:
1. New clutch fluid and bled properly, no air bubbles.
2. Clutch lever adjustment is set to furthest point out.
The bike had been tipped over at a standstill and that did bend the clutch lever slightly. I have been able to bend the clutch lever back by applying heat and pressure to it so its back to normal now.
I am wondering what else I should check? Thanks in advance, I have tried the search function but did not come up with much help there.
-John
creeping?
John;
either it isn't bled or the M/C piston isn't returning all the way because of the damage
it's just not pushing the slave far enough
John;
Noel,
Thanks for the help.
I am pretty certain that I bled it correctly.
Is there any physical way to check to M/C piston? or do I just have to replace it to see if it corrects the issue?
Noel,
no, you need to remove the M/C and clamp it to a 7/8" bar
then remove the reservoir cover and point the M/C downhill.....you want the return port at the high point....
then if you slowly squeeze the lever 5-10mm the M/C piston will bleed itself through the return port
NB;
you may have bent the lever on the other side of the fulcrum.....i haven't looked at the possibilities
i think i still have a short clutch lever i'll look tomorrow, you're welcome to try it......but i'd bleed it my way 1st
NB;
Noel,
Ok I'll try bleeding it that way first. I looked at the workshop manual and I think your method is similar?
Thanks!
Stock lever? (my CRG at full click, 6, and pulled all the way in doesn't totally engage the clutch). My factory lever does just fine.
I opened my oil filler cap today and squeezed the clutch lever while looking inside, I can see the clutch pressure plate moving in and out as I squeeze and release. So maybe the clutch slave is engaging and disengaging and my problem lies somewhere in the clutch plates?
outside chance;
too much play in clutch hub, hub nut loose....its happened
you can see the pressure plate move, but the clutch pack moves with it
not allowing a full release
outside chance;
I'm going to take a look at the hub this weekend, gotta drain the $70 worth of Amsoil I just put in :bash:
John;
make sure the clutch and slave are bled....
i start at the slave....by removing it
gently pump the piston out aways, then with the return port at the high spot, now with your fingers push the piston all the way back in
any air is now in the M/C, now bleed it
still have a dragging clutch?
then check the clutch
drain your oil into a clean pan and just reuse it :drummer:
John;
Will do...thanks Noel
sounds like the same problem I had with failing slave cylinder seals, once changed the clutch gave me full travel and the gear change was far better with no drag, hope this is of use regards banjo.
1 - 14 of 14 Posts
