1 - 3 of 3 Posts
It is normal for the armchair behind the brutal 1078 can be opened so easily? is that today I've found open when I went to pick up the bike and the truth that opens with ease, is there any solution?
The reat seat is sometimes difficult to open and close so it should not open easily. If it has come open, best guess is it wasn't closed properly in the first place. You need to hear it possitively click in place, otherwise yes it will pop open and probably fall off!
Re your lock, this happened on my bike, you will find a nut behind the lock, not easy to see and a bit of a fiddle, but just tighten this up and check it is not coming loose again after a few rides.
Just make sure you hear the seat click in place and you should be fine. Also when taking off the rear seat, it helps to push down on it when turning the key in the lock as this takes the pressure of the key and should avoid you bending it!
1 - 3 of 3 Posts
