Folks, this set of Brembo full floating 320mm rotors, calipers and master has been sitting in my garage for a long time. It was $1100.00 new in teh late 90's when I purchased it to upgrade my ZX-11c (ZZX for you over-the-pond folks). It has a minumum offset...maybe 1 mm...and everything a person with the need might need. The calipers and master will fit any Brembo non-radial mount.
I'm ready to make a SMOKIN' deal for someone who might have a use for this set: $500.00 USD and we'll work out shipping...
It's all brand new in the box ready to install.
The biggest issue is that these discs are 320mm and yours are 310mm.
If you can measure center to center on your caliper mounting bolts, I can tell you if the calipers will work.
Also, use the attached diagram to map your discs. You may need a spacer to move the calipers out 5mm to accomodate the 320mm discs..that is IF the offest and bolt pattern match up.
You should have a five-bolt pattern, so measure bolt-to-bolt centerline.
