Do I really have to take a fuse out the plug the trickle charger in? If so which one is it? The handbook isn't too clear.
yeah, factory supplied charger. I'm sure that there's something in the handbook about having to remove a fuse when using this. Will check.are you talking about the factory supplied charger, if so you don't , under the seat pull the sealing blank apart from the charging cable (its the one that doesn't go anywhere) and plug the charger connector in
I don't remove any fuse when charging. Just plug in under the rear seat.yeah, factory supplied charger. I'm sure that there's something in the handbook about having to remove a fuse when using this. Will check.
