1 - 3 of 3 Posts
This is for 4 pad Brembos only, the ones with the POS springs and pins
remove a caliper, with a large flat tip screwdriver twist it between the pads, pushing the
pistons all the way back in with the hose at the high point......do the other caliper
drain the M/C reservoir and wipe clean with a lint free cloth..... refill with new DOT 4
and pump the pistons back out to their ~ original position ......tie the brake lever part
way down to close the return port
now using the bleed screws remove the last of the old brake fluid from the calipers by
using the screwdriver again
hold a caliper upside down and remove the old pads, now put a new pad in and press
it down, now tilt it into place.....repeat
remount calipers, untie brake lever, pump brakes until they are firm
recheck fluid level.....
now there's no air in the system, you have new fluid and pads......
and best of all you didn't have to deal with the POS springs and pins
:popcorn:
Where are the pictures?
1 - 3 of 3 Posts
