I might be splitting hairs here but should I adjust the chain tension measurement from bottom of "fin" by the radius difference when changing from 41 to 43 tooth sprocket ?
Not splitting anything at all mate, add about 1mm per tooth increase.
This might sound funny, but if you go through all the manuals over the years and keep a close eye on the sprocket sizes, you would notice how the gap varies between 6mm right up to 9mm.
Play it safe, a bit more is better than too little.
SPR 750 owner manual has different settings for the 3 different size rear sprockets it came with....
