Hi there! Has anyone replaced the windscreen on the Rivale? I've just got my carbon windscreen from Motocomposites and it seems that the whole headlight needs to be dismantled in order to replace this item... I'm just a bit afraid to remove the headlight although I've got all the tools to do so. So anyone tried, or any suggestions?
Hi there! Has anyone replaced the windscreen on the Rivale?...
I did :)
Went for polycarbonate
Part 1 in the drawing:
http://shop.startwintrading.com/en/products/rivale/parts-3/-fairing-assembly--1
Main tool needed a screwdriver.
You also need two (2) hands.
Caveat
If one has got two left hands with 5 thumbs on each, job might be iffy.
Otherwise easy as pie to remove/replace.
I put on the Puig, took 10 minutes, no problems at all.
http://www.revzilla.com/motorcycle/puig-naked-new-generation-windscreen-mv-agusta-rivale-800-2014
