1 - 6 of 6 Posts
My friend bought me a RSR MOTO rear fender. It did not come with mounting hardware. No replies from RSR MOTO to my e mails. Site shows M5 bolts but how long ? Special bolts required ? Is the swing arm threaded under the rubber plugs ? Thanks for any info that can be passed along. Won't see the bike for several days. Stuck offshore at work
Thanks , Bubba
M5 wellnuts and if they don't come with the bolt, a hex head bolt long enough to grab the thread is fine. You'll need 3 I believe. Do not use Loctite. Hope this helps.
Just got this to my F4 and I believe it’s the same part for the brutale.
It is 3 bolts, and you will need the M5 wellnuts as stated. I believe that anything close to 15mm bolts are fine and probably not a problem if they are longer. I also made some rubber washers to go between the bolt head and the carbon piece.
Ordered a set of Strada 7 Racing Black wellnuts off amazon.looked like a low profile mount. Stainless Allen head bolt with nylon washer. Hope they are long enough. Thanks for the help
1 - 6 of 6 Posts
