1 - 9 of 9 Posts
Hi lads is there any easy way to fit my hugger or do i have to remove the rear wheel.I only have the bike a while & did not really want to remove the rear wheel especially with the rear wheel hub problems i keep hearing about.Thanks
Fitted mine without removing the wheel, fiddly but not impossible. Took about 15 minutes. This was on a 920 don't know if the earlier bikes have less clearance.
Discussion Starter · #5 ·
Mine is a 09 989R and i keep trying to convince myself it can be done but there is just so little space.There surely cant be much of a difference between your bike and mine so if you can do it then surely i can also.
Have no idea if there are more links on 920 chain but my bike was brand new with less than 200 miles on the clock so no stretch on the chain, as a maintenance engineer I have an advantage in being used to working in tight difficult to reach places.
1 - 9 of 9 Posts
