hey guys,
i got a new f4 mirror, but everytime i adjust it, it just returns back to it orginal position...
any ideas on how i can adjust?
i assume you are moving the actual mirror GLASS and not the whole mirror itself? If so you could undo the two screws underneath, slide the mirror out and give it a little bit of WD40 or something, could just be dry/stiff. Cant otherwise see a reason for it too play up.
i know they dont. but i cant even get it to match the other side. looking thought the left i see my elbow. looking through the right i can see my body.
when i goto adjust it. it moves but does hold in the new pos...?
If you remove the mirror from the housing and on the reverse, shave/cut down the small plastic 'lugs' (on the outside and top), it'll allow you to push the mirror out and up a bit more. Not a huge amount mind you, but I found it worthwhile.
lets face it, the mirrors are only installed so there is a place for the front turn indicators. They do have a nice view of my elbows though. Lots of cranking the head around.
