1 - 9 of 9 Posts
Can I decat my standard exhaust on my 2010 f4 and if so do I need to change the ecu to a racing ecu, I was told to drill out the cat is that correct thanks
yup i decat my standart exhaust on my f4 2010
but the bottom power now not to good so i have to order microtec ecu for repair that
I did it and the tuning was not that off, but till 5500 rpm is was quite lean.
Later I installed a MV corse ECU and then it was perfect!
This is how we did the decat. Should be somehow the same on the 2010...
http://www.mvagusta.net/forum/showthread.php?t=51770
so would i need a power commander and a racing ecu
No, just one of them, not both.
But actually you could try it with the standard ECU. That one will also regulate to a certain extend the tuning because of the lambda sensor. I did it like that in the beginning and dyno figures showed it was quite okay. Only the drivability in lower revs was not so good. Then I got the MV Corse ECU and that worked out great!!
Here is my story:
http://www.mvagusta.net/forum/showthread.php?t=50997
Different bike, but I think it still works the same...
1 - 9 of 9 Posts
