1 - 15 of 15 Posts
So I'm meticulously cleaning off bike last night and notice a what appears to be a small bubble on the side of my gas tank? It's about the size of mosquito bite, and I'm certain it wasn't there at purchase (which was this summer - 2017 B3 800).
So....what do I do? Is this the dreaded tank swell of some sort?
It always helps to provide photos.
On some older models the tank would bubble from the ethanol in gas. It was mostly a problem in the US. MV changed materials in later models to help with this problem.
Being yours is a newer model it shouldn't have the bubble issue.
My 2014 F3 tank was replaced and my friend's 2014 Brutale's tank was replaced too.
Take your bike to dealer so they get some pictures to send it off to MV.
Yeah I posted this at work, I will snap a photo and post it and send a pic to the dealer to see what's up. My Ducati SF had the tank replaced because the ethanol gas is shit out here, but the swelling on that bike was nothing like a little bubble....it was more of a crowding of seam along gas cap.
They're still using the same plastic crap they've always used. I'm on my third tank. in the USA we're protected by an ethanol law. It warranties the tank for five years. You should be covered and you should also expect this to occur again.
I did had exactly the same problem with my b3 '14, and i did the same thing but they didn't accept my tank, so i left my tank open whiteout fuel in it over winter(maybe little more) and wuoala la it's back, not enough but it was better, much better, then I do it all the time when i parked in garage, and there isn't anymore, from now on I'm trying to left min. fuel in as much as i can and that's it
1. Fkn ethanol in US
2. Wtf MV
3. Beter solution than spend $1500+ shipping
Ethanol gas is now a world wide problem.....no longer just a US foolishness. The tank plastic was supposedly reformulated by the supplier (Acerbis???) to address this. My '08 Brutale tank has never had a problem.
You should seal the tank if you think it will be damaged by ethanol.
Reactions: RBx
^^^ this.
Had the same swelling on my Ducati Monster tank, no bubbles, but the tank swells to the point it contacts the latch and crowds the seat. Anyhow, i let it dry out for a few months over the winter and used Caswell (sp?) Dragons Blood to coat the interior of the tank per manufacturer recommendations to protect against the ethanol. Again, this is from the ethanol poisoning. As Ed suggested, get a new tank and coat it before you install the tank and hopefully it will be the last tank you replace due to the bubbles. I wonder if letting the tank dry out for a few months will remove the bubble?
Hope that helps
USA ethanol law? Where did u hear this from? I asked my dealer about this and they said I would only have 2 yr warranty which is what the bike comes with and after that, it would have to come out of my pocket.
I think he is referring to the Federal (and California specific) Emissions Laws. These laws require components on highway legal motorcycles that affect exhaust or evaporative gas emissions (and noise) to function for 5 years or 30,000 kilometers (18.641 mikes).
That time/mileage is for larger bikes. Little bikes (200 cc for example) have shorter time/mileage periods, as do off-road vehicles.
If a covered component fails, causing the vehicle to exceed the allowed amount of pollutant (gasses or noise) emissions, the manufacturer is required to replace it free of cost to the consumer. So, if the fuel tank fails the evaporative emissions standard it would be covered.
Should an engine sensor (Coolant Temp, Air Temp, Manifold Pressure, etc), or component (gas cap vent, ignition coil, fuel injector, muffler etc) fail causing the engine to run poorly or evaporating gas to escape or the exhaust noise level become excessive it would be covered by the emissions warranty for the specified period.
I don't believe the swelling or bubbling of finish would be covered, unless you have the means to perform the tests required to prove evaporative emissions exceed the allowed limits.
If your bike has a grey round sticker under the seat near the tank it should have been traeted and should be ethanol safe .
The tank on my 1090RR was replaced under warranty several months ago. I specifically asked the dealer handling replacement if I should have the new tank sealed and was told that the new tanks are already sealed for ethanol. I did seal the tank of my YB10 at GTL and the price was around $300: Fix Motorcycle Gas Tank, Rust Removal, Lining, Sealing, Fuel tank
What’s considered a new tank? I currently have a 2015 brutale. There’s a small bubble and the shop was finally able to order a new under warranty (even after they told me it’s not covered). If it’s already coated, would coating it again add an extra layer of protection?
The tank warranty claim was originally initiated by the previous owner and it was done by his local dealer on the East Coast after we did the transaction. The bike arrived to me in Cali with a new tank installed. By new, I mean OE part from the manufacturer. This all happened about 6 months ago.
1 - 15 of 15 Posts
