Anyone changed the rear sproket on their 910?...to a higher gear? Find I can take off in second good enough. Thanks Foog:f4:
I swapped out my 43 rear to a 41. I can hardly notice the difference, probably because the 910 has a decent amount of torque. Maybe I should have gone with a 40.
I went 1 tooth bigger on the front - from 13 - 14, (equal to 3 on the back) left the back one alone.
This changed the feel of the bike dramatically - lost the frenzy at highway speeds, didn't notice any issue with first gear. I am very happy with the result. Only down side is that it also cost me the price of a "Yellow Box" needed so I could recalibrate the speedo correctly. I got one of the fisrt plug n play harness from them (last summer) - worked out ok. Bike is a 750 S
Hey, MV NV:
I notice that you are from Canada .... I thought that you couldn't import and register MV's into Canada? Would you mind shedding some light on this topic, as it has popped up from time to time?
