Which tap sizes would be best to add to shop tools?
Which (Thread Pitch Sizes) are correct for early MV screws?
General Purpose Tap
Closed-End Hole
Screw Size x Pitch / Tap Size
M4 x (0.75mm, 0.70mm) /
M5 x (1.00mm, 0.90mm, 0.80mm) /
M6 x 1mm / 5.00mm
M8 x (1.25mm, 1.00mm) /
M10 x (1.50mm, 1.25mm, 1.00mm) /
M12 x (1.75mm, 1.50mm, 1.25mm) /
Edward......
MV screws are a complete goat fuck......
M6 x 1mm / 5.00mm
M4 x 0.7mm
M5 x 0.8mm
M6 x 1.0mm
M8 x 1.25mm
M10 x 1.25mm a Japanese thread?? M10 x 1.0 spark plug and brake line fittings thread
M12 x 1.25 another spark plug thread that MV uses??
The picture shows my metric taps less the 3 spark plug taps
Edward......
This I feared. WHY oh WHY MV?????
I guess a tap at a time when needed. I prefer NOT to work that way.
Print to scale Metric Thread Pitch chart will help when taming the goat. McMaster Carr is certainly a great source for taps.
Reviewing the parts list this is what I've found. Keep in mind there are corresponding nuts to the larger sizes.
M10 8H0082751
Front Wheel, mounting caliper
#17 but #16 is a bolt. Goat laugh here
https://shop.startwintrading.com/en/products/b4/new-folder-64/front-wheel-assembly-44
M12 8000A0841
#1 Front Fork Right
https://shop.startwintrading.com/en/products/b4/new-folder-64/front-fork-right-24
M12 800084867
#14 Frame
https://shop.startwintrading.com/en/products/b4/new-folder-64/frame-assembly-22
M15 800086395
#32 Swingarm Assembly
https://shop.startwintrading.com/en/products/b4/new-folder-64/swingarm-assembly-31
Edward;
I can't ever remember needing a tap for use on a motorcycle
That said I've Heli-Coiled a few things for customers.......and for shits and giggles all the 6mm holes in my
Abarth motor......my neighbor owns an insert company so they were free:grin2:
Noel,
Normally there is rarely if ever a need unless severe corrosion or jammed all up with threadlock. Historically, my K75s definitely was a good patient for occasional thread cleaning since 87. But... then again that was an all-weather bike for a 150,000 miles venture, from crazy high-wind sandstorms, hurricane washouts, a freaking tornado run in, painful hail and torrential downpours --and of course snow! Certainly not with my MV. :wink2:
Stuck bolts?
As tested by the guys on the North Sea oil platforms.......
Best thing there is, is a 50/50 mix of ATF and acetone
Better than even Kroil.....and that stuff is amazing :grin2:
Buying taps or dies? Screw McMaster-Carr
Get real high speed cobalt taps and dies from your local machinist's supply
They usually speak cash......for a discount too >:)>:)
