1 - 20 of 23 Posts
When you do that you can no longer hook up the spring is that correct? I will be doing this pretty soon too...
Correct. You can move the tab and just weld it at a point closer to the headers, or leave it off completely. I have chosen to leave it off. No problems so far.
Hmmm I could always just safety wire it or something like that... Or yeah have that tab re-welded at the appropriate distance...
I put mine on without cutting. Pics are in album. Would probably look better shorter. I may do that in the future.
Just wondering how many of you with the arrow thunder have pulled out the Db killer. Took mine out and noticed a slight loss in power just off of idle. Not a big deal just wondering if this happens to other Brutes?
Not very lucky..
I occasionally ride without it and can't feel any difference in power delivery
Then again I did buy a new eprom from FBF and gave them my specs (thunder exhaust, BMC air filter)
Ok, don´t know about loosing power just off of idle, not that concerned either - i´m never there, but my machine goes more bezerk over 9000 without the killer and thats more interesting to me: ) Edit: The bike is setup with PCIII
Unfortunately it sounds way (way) to much without the killer, I have now bought an extra one to experiment with, wil shorten it to try to tune the sound a bit, and hopefully end up somewhere in between..
Darkside,
Nice setup! Notice a difference with the Eprom? Was thinking of getting one. As to the Db killer. It's not really a big deal because there is a noticeable power increase up in the higher revs. I will most likely be doing most of my street riding with it in for more usable power.
Not very lucky..
To me, no difference between eproms. I think I should have just bought the power commander and had it properly tuned instead of going the generic route :conveyer:
the_thomas,
Just a thought. I've tried cutting down the Db killer in other exhaust systems as well. I have had much better luck with porting instead. Really allows you to fine tune the sound you want. And helps with power as well!!
the_thomas,
Aha, thanks for the advise, this could very well become a very stupid expensive experiment (the little thing costed me 90 usd after taxes and shipping :rant:)
DAMN!!!! That's rough. Good luck with the experiment. On the I4 engines lots of small holes sound the best. But that's just my opinion.
1 - 20 of 23 Posts
