1 - 16 of 16 Posts
Hi there!
Anybody knows what is the torque for the swing arm hub bolts in the Brute 990R?
I need this information to tighten the chain....I have been looking for this information in the manuals but no luck.
Thanks,
Celica
Don't know the numbers for 990/1090 (guessing at the same though 28-32 Nm for the hub pinch bolts) I would err on the slack side for chain adjustment especially as the 90s have a longer swinging arm - after you have finished I'd sit on it and get someone else to check for free play...
I known the specification for the pre 2010 models...28-32Nm. But the new models have a new redesigned hub, that's why I wondering if the hub bolts torque have change...
I have not seen any sticker on the hub with the bolts torque...
Same as earlier, the 990/1090 manual states 28-32nm
Chris
Chris,
Where have you found this information? I have checked european and USA manuals for the 990/1090 and I cannot find it!
Please, let me know...
Torque
Chris,
In addition to being printed on a data label on the rear hub, the info is printed numerous times in the manual. Below is a screen shot from page B-55.
Best wishes,
Dick
Dick,
I do not have that manual... :(
Is it a PDF or printed version? Does it come with your bike or have you ordered?
Regards,
CarlosF.
Hi Celics, the manual I received is a PDF. There are two of them, a Chassis manual, and an Engine manual. They overlap one another bit, but the engine manual goes into complete disassembly of the engine and associated parts, in great detail.
I received both manuals from the dealer when he delivered the bike.
Best wishes,
Dick
Best wishes,
Dick
So, I will talk with my dealer to request mine.
Thanks,
CarlosF.
Best wishes,
Dick
Can you send me a copy or are thay available from MV do you know? I aint got em either ....
Both are available from the dealer.....IIRC, I believe they came on a USB stick when you buy a bike (in the presentation box)...Both PDF's are large and can't be emailed.
Discussion Starter #16
I have talked with my Dealer in Spain...In Europe the 990/1090 workshop manuals are not provided with the bike... :(
Anybody can upload the 990/1090 workshop manuals and share the links? Pleeeeeeaseeeee.....
1 - 16 of 16 Posts
