@silentservice703Are your coils failed?
@Deano ,"I also agree,
never heard that they failed in an MV."
Believe me they do. Anytime, anywhere and can come back just as quick. Always have a spare to hand.
Deano
Ed,Beru coils..... you may have to make a wire loom to connect the coil to your harness as the 910 has the wire loom built in.....most other vehicles the wires plug into the coil itself.
Appreciate it Ed,Beru coils..... you may have to make a wire loom to connect the coil to your harness as the 910 has the wire loom built in.....most other vehicles the wires plug into the coil itself.
P.S.- obviously since they had already been used, no wire loom fix needed.Appreciate it Ed,
I found a gentlman in Italy that had a set of gently used ones. Took a chance on them and it seems to have cleared up all issues. Funny enough, when I put my meter on all of them; they tested fine but when I changed 2 it cleared right up. Went ahead and changed the rest as well since I already had them and put the other 3 back for spares.
