Hi all, recently took my brute in for a health check, turns out i need some new headstock bearings:bawling: Does anyone know of an after market bearing set? And were to get them from, thanks for your help:f4:
Check with the knurl. He is the bearing guy. If you can't find bearings, you can replace the entire headstock.
Thanks for your help. Does anyone know what i check for tightness on the head, just to make sure nothing is loose, before a take it apart and fit bearings.
Make sure the top collar is tight on the aluminum headstock. Don't use a drift to tighten it! Order the correct socket.
The head bearings I got for my 750 were Ducati ST4...
