1 - 6 of 6 Posts
Dear all,
This morning while going to the office I had a problem with my motorcycle. My brutale has now 5331km and she stopped while running. Water temperature 91 degree and suddenly the red oil light + red battery light appeared on the gauges and bike stopped running. I switched off the bike and restarted it normally. After 1 more km same thing... Do you know this type of problem?
Never happened till today.
Also check your ground connections. You could simply have a loose wire.
Alternator and battery checked: 100% ok.
Battery voltage 12.2 and when engine is on 14.5-14.7
I'll check also all ground connections. Hope this should solve the problem.
Saturday morning I started my bike and I decided to go to Romanian seaside having no more strange symptoms on Friday. Everything was normal till I arrived at destination 230KM away from my city. Suddenly the battery red light appeared on the gauges and in 3 minutes all gauges stopped working and my bike died. I checked the 40A fuse under my seat and it was blown. I replaced it, started the bike and in the next 10 minutes same think...a new fuse blown
Any idea about this kind of problem?
1 - 6 of 6 Posts
