I'm looking for a steering damper. I assume what's out there don't work on the Dragster.
Whats wrong with the suspension?Try getting your suspension sorted first, it makes a world of difference, check out the suspension thread on the brutale 800![]()
AHh. so you mean just go get it adjusted.Nothing wrong with it apart from the adjustment range being too narrow on the forks, it's just not set up very well from stock, there was way too little rebound damping on mine.
Yes, you need some brackets to attach it to your exhaust. Won't help you much i think, the pan is splitted so any debree would still hammer your underneaths.I'm thinking about adding the Dragster bellypan to my B800. The area around the oil drain plug gets beat up and I think a bit of deflection would help. I assume it's a simple bolt on...?
