1 - 20 of 24 Posts
Hey all,
Looking for a full system for my '05 750.
I've been dealing with lousy throttle response on my bike for the last few months, and I figure I may as well buy an exhaust before I throw it on a Dyno. At first I was really in to the Arrow Thunder exhaust, but the more I look at the stock exhaust, the more I want an MV Corse titanium system.
The MV titanium system only wighs 9.6 lbs, can't seem to find the weight on the arrow.
Are they both street legal?
Is only the can on the arrow titanium, or are the headers as well?
Which is louder(looking for the quieter one)?
How do performance figures stack up?
Anybody have experience with either system?
Nhonor,
Have run a full Arrow system (headers, midpipe, muffler) on my 2009 1078. Pretty loud even with the baffle(?) in. Not as loud as the H.P. Corse (with straight baffle) I run now. Both made perceived power gains over stock.
But either exhaust would have been a disappointment if I hadn't fitted a Microtech from Xbikes first. A new exhaust wont fix the lousy throttle response and other traits associated with the OEM ecu.
It's expensive but well worth it. You'll find that your old bike is a heap nicer to ride even without a new exhaust. Can have all the bling in the world but if it's a bitch to ride it disappoints. I'm only speaking from experience with an Xbikes Microtech. Other aftermarket units may do as well but maybe without the service Chris gives.
Deano
Nhonor,
Deano
Deano thanks for the insight,
I've done some searching on the forum and have yet to see any threads about a Microtech ECU for a brute 750. Do they make one? Honestly I haven't really put much thought into Microtech as I'm in the states, and would rather put the bike on a Dyno then download a map.
I'm also a stones throw away from Ferracci, and have spoken with Eraldo extensively about engine tuning, and how they do it. He recommend an EPROM with an in house custom map. Being that they're the best place in my area I'm compelled to do it their way. Getting the bike on a Dyno and getting the fueling sorted is definitely on my list of "to do's."
The question is, should I do it now, maybe buy an exhaust later, and have to do it again? Or should I just spend the money now and be done with it? The other question is do I even want a new exhaust/is it worth it?
I'm essentially an indentured servant till June 5th, and will doubtfully have time to jump down to PA before then, so I'm just trying to put all my ducks in a row before I pull the trigger on anything.
I can only speak to my own experience not everything you asked sorry; but here it is.
I went for a Arrow (really its a Tamburini Corse, but same thing) slip-on and cat removal with a PCIII and custom tune with these results
Forget HP for now and look at the graph on bottom. Notice the low RPM fueling on the stock bike was really poor and rich in spots. I was getting about 19-21 mpg and it was hard to take a passenger because the throttle was really jerky. I had to really feather the clutch.
After tuning its much improved and way more ride-able with about 26-30 mpg.
As for power gains the slip-on and PCIII together only added maybe 3hp at the top and did little help fueling. The real benefit to the PCIII was the mapping.
Your results might very but I think in the end having the bike remapped will be more beneficial then the exhaust alone.
As for weight, I haven't weight mine but its way lighter then the stock pipe. Good luck with what ever you do.
EDIT: wanted to add, I don't know how close you are to Brookfield, CT but my tune was done by Dyno Solutions. John is an MV owner and a great tuner. If you give him a call I'm sure he wouldn't mine giving you some advice. He also goes by Air-Fuel on this site but I don't think hes logged on here in a couple years.
I have a Microtec ECU on my Brutale 750s - fitted and tuned by Chris at X-bikes. Peak power is 114 bhp too but the main gains are lower down where you spend most of the time on a Brutale.
Runs like a dream compared to stock. I have experience with Dynojet PCs and Bazzaz units but the Microtec is by far the best in terms of throttle response - the transition between on and off.
Nhonor,
Does your 750s already have the Cat removed? if not then thats a must for the heat and weight saving, then if your are going to do a PCIII ( i had one on my old 910R and loved it) then get the air filter and cat bypass sorted thats all you need to have sorted Brute, or as you said let Ferracci take it and do their thing, if its not to your liking you can always take it back and ask them to do more work until you are happy, might also be the cheapest way??
James
Thanks for all the responses.
My Brute has an arrow de-cat mid pipe, and I'm not sure what air filter it has currently. As you've all stated the horsepower gains aren't really what I'm looking for, just trying to smooth out the terrible low end response.
Motoarch, I'm only an hour and a half from Brookfield, so I'll definitely give john a shout. Did you attempt to do any tuning before you got the new exhaust? Do you think I'll have the flexibility I would with a full system? If not do you think I'll be able to get it done with my stock/mid pipe configuration?
Biaggi, (please tell me your name is max..) thanks for confirming the exhistance of a microtech Ecu for the 750. I'll definately reach out to Chris when I get a chance to get some more info. Considering he's had nothing but shining reviews I'm sure it's worth at the very least looking in to.
James, I'm not necessarily looking for the cheapest way, just looking to be cost effective. What I'm getting out of this is that the performance gains may not be worth the new cans. I'm just still wondering if I'll be able to smooth everything out with my current set up, and if its worth the money for the loss of 10lbs. Maybe I should just get some rims instead?
Thanks again for all the insight, I haven't had time to ride outside of my 15 minute commute to/from work so It's been too easy to obsess about all this.
I didn't do any tuning without the new exhaust but the tuning is all that really matters. We ran a base line with stock an the new exhaust and the new exhaust did little to help the fueling and throttle issues. Even the pc3 with default map didnt help much. The difference came from installing the custom map with the pc3. If you were to do anything that's what I would recommend. Chaning an air filter and exhaust wont do much of anything if the air fuel ratio is still wrong and it will be. In fact doin those things with out a map will probable make things worse.
I don't get it, on the papers of my bike it says 93kW (~127bhp). Is it because of age that it only gets 114bhp on the dynamo or am I missing something here? And I would think adding the arrow thunder (and removing the cat) would even make the bhp higher ...
Are you talking crank or rear wheel? There is a loss between the two of about 15%.
Hey all. If there is anyone getting rid of a catalytic converter I'm very interested in trying to make an exhaust out of one. I'm happy to pay for postage if not in bris Australia. Thanks in advance
I managed to score a cat from a guy in NSW. I've got a sheety mate who's gonna help me with the build but I reckon we can make a pretty shweet exhaust from it. Will post some pics up here in case anyone wants to do it themselves in future.
In order to get it straight...(sorry for using with this old thread but didn't want to open another new for the same subject)
I have made the following changes in my old 750 S Brutale 2004:
1. upgraded the water pump with the one of DC (racing) (maybe its irrelevant with the exhaust, sorry for that)
2. changed the exhaust with a full MV agusta corse titanium
3. changed the air filter with a DNA
4. Changed eprom with the MV agusta race one
After doing those things I have to say that the sound is perfect and I'm pretty sure I can feel more power in high rpm but I have issues when the bike runs in low rpm...It run very weak & the fuel consumption has gone crazy (120km for the light)
...so...what is the next step? Dyno? change the ECU?
thanks in advance
ECU ... get it tuned or a chip. Or you can replace it.
Thanks for the quick response
ECU: I found a microtec for 850€+ shipping :eek: and I'm not sure that it can be placed on the 750s, so the second best,as I understand is to visit a dyno in order to tune it, and that's a go.
Chip? Other than the race eprom? Or eprom upgrade is not a chip?
So for the last suggestion, to replace the bike...I just don't want to...I always wanted a fist "edition" tamburini's bike. I'll keep it.
I wasn't suggesting replacing the bike...I was suggesting replacing the eprom with one from Merc07 on this forum.
Which ECU is currently in your bike? Does the Brutale 70 have the 1.6M or the 5SM?
If you go Microtec, I'd suggest talking with Chris at X-Bikes.
Sorry for that my mistake!!:D
The honest answer to your question is: I really don't know! How can I check? I was looking here:OEM Spare parts for MV Agusta motorcycles not sure!!
Microtec is a pretty expensive solution:(...so I'll try to avoid it at first...then I'll see
^ The problem is that I bought the bike at 2012, the preview owner had already changed the ECU cause he had problems with the first one, so...not sure if he had installed the 1/6M again...
I took o photo of the old eprom, if it helps in order to have o clue!!
I going to read the link with the diagnostic software, but the fist quick look assumption on the thread is "it's all Chinese to me" and merc07 has done a wonderful job..but for more "handy" men than myself
Thanks again silentservice703 you are very helpful!
1 - 20 of 24 Posts
