1 - 2 of 2 Posts
I read on other forum that the Brutale 750 should be discontinued on 2006 models.
Thru or false ?
Can Be both, depending on the market:
As the press officer Danielle stated last june. If there is a demand for the 750 they will produce it. But it has to be a batch of a minimum of 200. So if importers order them and there is enough demand they will still produce the 750 F4, if it's the same with the brutale I do not know. And there is another issue probabaly that they are not able to produce more than 30 enignes/bikes a day because of limited test equipment. So what model gets priority is the question!
1 - 2 of 2 Posts
