Hi MV Guru's
I'm fitting a Denali horn on to my 2012 B3 and I need a +ve feed from the battery.
Can I splice it out of the battery charging fly-lead, or is there a better way; maybe a spare connection in the fuse box?
Any feedback would be appreciated.
Thanks....
Have you looked at the wiring diagram?
You should be able to splice off the lead you suggest. I would suggest a horn specific fuse.
Hi MV Guru's
Thanks....
Um, use the stock horn wiring? You might need to lenghten the wires if you change the mounting location
:wink2:
Thanks for the replies.
The new horn has a compressor and runs a 30 amp fuse through a relay; so using the existing horn circuit is out.
I think it's safe to use the battery charging lead as that is 30 amp also.
They'll hear the horn now and it sounds Italian like a Maserati or Ferrari horn.
Ride safe all...
I put an Ear Cannon on my Ducati Monster project. It is quite a horn.
