1 - 6 of 6 Posts
Hi all
I went to start my Brutale 1090 (my2013) for the first time in about a month today and... nothing. The starter wouldn't spin up.
The dash start up diagnostic didn't give any fault codes when turned on.
I did disconnect the battery recently, but only for a few minutes whist I fitted some charging leads.
I have checked all of the fuses and they seem ok. When turning the ignition on, the bike goes through its checkout and it sounds like the fuel pump is priming ok.
I have re entered the key code in case disconnecting the battery caused a problem with the immobiliser, but to no avail.
Hit the starter button and a relay can be heard switching, but thats it, it does't even try to turn over.
All suggestions welcome.
Trickle charge your battery for 24 hours.
Try to start the bike.
It should start.
Then, replace the battery with a quality unit from the trusted manufacturer of your choice.
Now, go out and buy a quality battery.
When you change out the battery, be very careful about polarity and the lead hood-ups.
1 - 6 of 6 Posts
