Ok so just about to fit a new chain to the Brutale having bought a 110link chain to discover that the chain on the bike has 108 links!!
Question to all, is this correct?
Many thanks
Sprocket Centre says 110 links,I suppose they could be wrong.
I always lay the old chain alongside the new chain and cut to length.
Put your new sprockets on and wrap the chain around them and end the suspense
As long as you have rearward movement available you should be good to go
Modern chains don't stretch much
:D Yep did that first Noel, hence the queery, it seems after searching around that 108 seems to be the number. I did initially wonder if the hub had been adjusted to far forward but that's not the case. Pretty sure the chain is the original from the factory also so it should be correct ;)
