Bike is 2012 F4r with Nissin brake and clutch master cylinders. I have some Brembo radials I want to install. The issue is the outlet banjo bolts are in from the side on the Nissins and in from the bottom on the brembos. I assume I either need new brake lines or some type of 90 degree adaptor to use the stock brake lines. Any ideas or thoughts on how to do this mod?:stickpoke
bikefalcon1;
which radial Brembos?
the OEM Aprilia Brembo radial clutch M/Cs aren't worth putting fluid in.....
go look on the Aprilia Forum for problems with the POS....
they eat seals that Brembo doesn't sell.....I found them though
:popcorn:
