Sorry to hear you did not get the experience which you negotiated and the dealer agreed to deliver. Let them know you will blast on social media along with posting your written agreement. As far as damages, post those pics too. Let them know before you do it and see what they say. If they still will not do anything about it, then its your choice to small claims or social media, or both. If you can live with the damages that sound quite minimal and should require some touch up, can go about it yourself and move on.
The bike will show wear in no time anyways, but if you plan to let it sit to stare at then you should chase the cosmetic damages. BTW your lower air duct on the fairing is popped out in your pic. You will need to reset it, hopefully the tab is intact behind it. no bike is perfect and that is why I spend time prior to riding to sort all the little stuff out.
I have a little tiny chip underneath the belly pan and I touched it up with clear for now. It cannot be seen but I scour every millimeter of the bike. I installed a COX radiator guard because I plan on letting her go out and play once in a while. I will get touch up paint to prepare for those minor stone chips which are inevitable or else put some detailer paint protect film on the frontal areas. I asked for the highest quality delivery and prep but I did not expect them to achieve 100% perfection, its simply not possible unless dealer put a swarm of people on it, from a paint detailing expert for touching up shipping scratches to a tech to align and tighten everything. That sort of service would require a lot more on the initial spend, IMO. This bike have perfection far exceeding the Duc in terms of design cosmetic refinement, but the physical execution is only slightly above Ducati in my observation. The paint is more beautifully applied. The handworked nature of the MV is clearly evident, whereas the Duc 1199 appears to be more mass produced. What I mean by that is that the Duc has more paint imperfections, thinner in some areas sprayed. The defects on the Duc look like the kind that you will find on 100 units the same exact way, whereas, the imperfections on the MV look like one offs and where no two of the same model will be alike, hard to explain. The MV has a soul, no doubt.
