will the brake rotors from a 1090RR swap over to a 2007 F4R. Both are 320mm but not sure about the mounting holes and I don't have the F4 anymore to compare
Hmmm, if I ever got my F4 out of the trailer, I could check...perhaps this evening.
then all you need is a Brutale to check it against. Part number comparison would be the way to go
I have the 1090RR.....would that help?
It's the same George, all the mounting holes are the same, it's the off-set that I was worried about, but that's also fine. The only differences are sometimes the disc thickness, but that makes no difference to mounting.
I am not an expert on the rotors but I do know there is a 10mm offset
