1 - 3 of 3 Posts
I need to install front blinkers, the front used to be stock, the rears are already aftermarket.
what are the rules on buying aftermarket blinkers for an 06' Brutale 910...Ive seen a lot of posts on resistor relays or something like that so they operate and not blow up the ohhh so famous SPU. What do you guys recommend?
Hi bud,
The aftermarket units will not cause any problems with the SPU (it has its own challenges to deal with ;-) ).
Yes, you will need resisters for LED units - @Gremmin posted some info on what he has done on his 901R.
I have LED front and rears with no problems... straight from the package to the bike... well the rears are a custom job of mine made with stupid bright 10mm LEDs buried inside the grab handle area with lenses over it. Dont have any load resistors (other than what is needed for the LEDs to run off 12v (220ohm 1/4watt per LED). Never had a problem. Had it this way for 3 years now. blinks at the same rate.
oh yeah, and im on an 08 910S.
- Justin
1 - 3 of 3 Posts
